jacjam
Here I am again with this idle speed query. Our car has been back to the garage to rectify the cold starting problem. However I am not satisfied that the result is how MB designed the car to operate.
Perhaps you could tell me if the following is normal behaviour for a '93 190E 2.0 Auto.
The car starts from cold 1st time with no accelerator, the revs rise immediately to ca.1500 rpm, then after 3-4 seconds they drop to 500 rpm and the car only just ticks over, if you apply some accelerator the car stutters but continues to run.
Surely the car should rev high on cold start for longer than a few seconds.
Idle speed in Drive/Neutral when warm is ca.750 rpm. Idle is lumpy though not smooth as you would expect.
Help/advice would be great.
8)
8)
