I recently purchased a water pump from GSF for a 1991 190E 1.8 Manual. On removal of the old pump we noticed that there is a hole approx 10mm dia. on the right hand side of the casing from which it was leaking. On the replacement, instead of a hole on the right, there is a small pipe protruding from the bottom of the casing which looks as though it should have a small dia. hose attached.
Everything else seems to match perfectly except this particular detail. Can anyone tell me if this is important or can we ignore it as a minor modification and go ahead and install it regardless?
I have also sent this message to GSF and await their reply.
Thanks in advance for your help.
Al.
Al.
