1977 350sl fuel tank
scott2gogo
is there an inbuilt filter in the tank, was gonna take tank out and give it good clean out as standing for couple years, but seems bitch of a job as connection out of tank will not undo and dont want to wreck the fitting as tank will not come out with fitting on, am going to use wet vac with thin tube on and try to clean out asd best as poss ?, have blown airline up hose to try and clean what is in the tank, cheers andy
scott2gogo
malcolm, thanks a lot ,seems my prob is with the strainer will have to try and clean and blow it out from outside as its corroded on and dont want to damage anything , cheers andy
scott2gogo
197 35osl
malcolm, have cleaned as much as poss and am waiting new hose pump to filter, if this has'nt done the trick what is strainer made of will i be able to punch a hole in it with a long screwdriver and then i will fit new filter to the hose going into the pump, cheers andy
osc
1971 450SL; 1989 911 3.2 Carrera Targa; 1999 BMW 728i
did you manage to remove the strainer - can you advise on the process. i need to do mine on a 107
the strainer is the very large hex, the fuel pipe screws in with the smaller hex (22mm?) but the strainer is separate. it is very difficult to access due to the proximity of drive shafts and floor pan but will come out with the correct socket (46mm ish from memory).
