AstroturfHead
- Sep 1, 2003
Hi, as the subject says, I own a 1978 450SL. When the car is running and I'm inside, if I press the lock closed it will close the passenger door. However, when I stop the car and get out and use my key, it doesn't automatically close the passenger.
It did, however, work correctly before I put the radiator in, a full week ago. I put a new radiator in the car and now it does not work correctly.
I just tested it again. When the car is on, the locks work perfect. When I stop the car, only if I immeditaly press the lock does it lock the other side. If I get out of the car, it will not lock the other side. I know these are vacuum regulated, and my breaks still hold vacuum after 2 or 3 hours after I turn off the car. Can somebody help me? Thank you.
