Beautifulbodywork
- Oct 21, 2008
When it rains heavily my beloved Mercedes 1984 230CE coupe leaks water in. I park it on a driveway with a slight incline and in the mornings there is water sometimes under the mat on the drivers' side on the drivers' floor area. There is also water immediately behind also on the drivers' side in back seat passenger floor area. But here it's confined to the length of the carpet line soaked through where floor meets upper part of passenger floor area. I've had the lower window rubbers each side replaced because they were perished and that helps but water is still coming through. Is it coming through sunroof drainage areas or from underneath the car? What can I do to keep the car dry inside? It smells of damp now and the water will rot the chassis if I'm not careful.
