Compressor and refrigerant-containing parts are good; blower comes on and will run about 20 seconds at High speed, then stops abruptly and will not come back on. If the ACC is turned off, then back on, it will repeat the 20 second routine.
Additionally, I note the system seems to only operate with automatic blower speed; it will not respond to either the High or Low blower-speed selector buttons (this symptom was present prior to the development of this problem, however). Hot air seeps from the windscreen demister vents and the right and left panel vents when the system is off, making it somewhat uncomfortable (and increasingly so, as Spring has arrived).
Any troubleshooting help and description of your experiences would be most helpful.
Regards, from Randy
Regards, from Randy
