My service on this revealed a tiny oil leak and the same for power steering. The oil light still comes on occasionally but I suspect that this is a sensor fault. I had new pads on the front and it's running well.
I noticed that the rear side window seals are leaking slightly, any advice on getting these replaced? Is it difficult/expensive?
Also, I can't get the height adjusters on the front seats to work, I don't believe they're broken, so how do I sort them out/use them properly?
Where's the best place (cheapest) to get 2 headlight lenses please, both have cracks in. Are the plastic protectors cheap and do they work with the wipers on the headlights?
You lot are all very helpful, thanks
