1990 300E won't start. Its not the battery... but what is it
Status
Not open for further replies.
300Eboy
New Registration
Problem: Car won't start
symptoms: The RPM gauge goes up to about 100 or so but engine doesnt start.
Is it the starter, fuel line, or what? I have no clue, I'd appreciate some help. Thanks :)
Malcolm Brown
Macclesfield, Cheshire
www.******************.co.uk
The engine must be turning over for the rev counter to register, so it won't be the starter motor.
Do you hear a buzz from around the offside rear suspension for a couple of seconds after turning the ignition key to 'on' (not 'start')? This would be the fuel pump priming the system. If not, it could be a fuel pump or fuel pump relay problem.
kiwi_bloke
New Zealand
check the basics
Have a look for all the common things
take one spark plug out and crank....see if its sparking (be sure not to touch it other wise u will know about it
If theres spark then ur right in this area. There is a chance even if you have a spark your plugs could be knackered as i had this problem.
Otherwise take one of the metal fuel lines off (be sure to have a rag handy and release the pressure slowly) Crank and see if there is fuel here. If there is then your good in this area.
Was your car running good previously? or were there symptoms there was something rong? Come back and let us know what the results are then we'll probably be able to get closer to the problem
cheers and good luck
josh
Status
