1990 300TE oil pump needs replacing - help!
betaspyder
Hi there. My 1990 300TE has developed an oil pump leak.
Does anyone know best place to get a replacement - do I have to buy new or would reconditioned do? (Are these repairable??) What should I pay?
How easy is it to fit? Don't mind a bit of DIY but don't want to get into anything complicated/special tools etc. Would I need any other bits - seals etc?
Many thanks - hoping some M-B guru can give me a steer - many thanks!
Just one question, how do you know its leaking.
;alcolm
malcolm E53 AMG
Replacemnts are available from KMS on an exchange basis, but as Malcolm says make sure that it is faulty.
Contact tel no. 0121 753 6454 (Birmingham)
0208 438 1010 (London)
On my 300TE I left the job left to a competent garage as the pump supplies the power steering rack and the rear self levelling suspension and requires the removal of the serpentine belt (might be worth replacing the belt at the same time).
Also have the rear levelling suspension supply pipes checked for leaks, they are prone to corossion at the body mounting points so a touch of waxoil doesn't go amiss.
B
betaspyder
Many thanks for the advice
Many thanks for the advice - sounds like I should leave this to a professional mechanic - I am working on the assumption that it is an oil pump leak based on advice from a friend who looked at it. The leak is from underneath the front nearside corner of the car to the front of the nearside wheel and away from the engine itself. The oil is gathering on to some low level pipes and dripping off from there - Regards
clive williams
Where do the auto transmission cooler pipes run? On my 500E the cooler pipes were on the n/s underneath the power steering pump. I thought that the original leak was from the pump. In fact it was a badly made joint on the flexible pipe, which had lasted 200k mls before it was so bad it was detectable/traceable.
Clive
500E
E320CDIT210
B
betaspyder
Thanks for this - looks like I should check all the pipes more carefully first before rushing to replace the oil pump - Cheers
