Mikesmerc
- Jul 3, 2003
- Location
- Co.Cork IRL
- 2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
When trying to start my 560 the car hesitates to start and the exhaust fumes are pushed back through the air cleaner vacuum pipes etc. This indicates to me that the ignition timing is out. When she starts she runs smoothly but the idle speed increases as the water temp increases. When warm she ticks over at 1100rpm, could this be caused by the timing as well? I looked at the distributor to see if it had moved but it had not, disconnected the cold start injector and gapped the plugs(0.8) but with no effect. If I press the accelerator quickley she hesitates then revs, if I press it gently it revs ok.
If anyone has any other other ideas/suggestions I would gratfully appreciate it.
Regards
Mike
Regards
Mike
