kevinnathanael
- Dec 6, 2023
- 1991 300TE-24V
I have a 1991 300 TE–24V M104 engine with the following symptoms:
- Use the vehicle up to warm (doesn’t have to reach 80 degrees C), sometimes only a 15 min drive
- Leave the vehicle for 30 mins – 1 hr (this is vital since if I restart the car immediately, there is no issue)
- Upon restart, sometimes the car would misfire, but not all the time
- Sometimes switching the car off then starting it back up immediately would make it normal
- Other times it may have difficulty starting, or misfire would continue and car would have no power with low idle rpm and rough running. (Some times I would restart 20+ times and misfire still continues, I would have to wait a longer time to let it sit till it goes normal again)
- 8 spark plugs (correct Bosch non-resistance)
- One of the two fuel pumps (since the other is normal)
- Fuel accumulator
- Idle control valve (Bosch)
- Air flow Potentiometer
- Distributor cap and rotor (both Bosch)
- Bosch coil
- Camshaft Position Sensor
- ECU switched to another used unit
- OVP Relay switched to another used unit
- MAS Relay switched to another used unit
- Crankshaft position sensor cable switched to another used unit
- HT Leads seem to be new (Beru)
