C
cross
I need to top up to the full mark on the dipstick - the gearbox is transmission 722428 03 341906 .
The existing oil is clean as a whistle and clear in colour ( i.e. is not coloured red)
I understand that recommended oils are Shell Donax TAD, Castrol TQD, BP Autran MBX and the info I get from the internet on all of these is that they all are red in colour.
My questions are
1) I have Fuchs ATF 3000 which is red and according to its spec is suitable for my car
2) are clear and red fluids compatible/interchangeable - I don't want to have to drain and refill if I can avoid it ?
3) The gearbox dipstick is marked with a dual graduation one one side in Centigrade and on the other side the same dual graduation in Fahrenheit.
On the centigrade side there appears to be a maximum notch at 80C and lower down the dipstick, a minimum notch at 30C - the corresponding F numbers on the other side are 180 and 90.
Is this an alternative reading for a hot box and a cold box ?
Any info will be much appreciated
My questions are
