1994 320CE soft top adjustment
AJL
Dublin
320CA, 220CE, 190E, C180 estate, Land Rover Discovery II, VW Golf
My soft top is slightly out of line at the front and as a result the driver side must be pushed into the locking mechanism from outside. I know there are 2 adjustable bolts that the frame rests on behind the rear window but these appear to just adjust the roof height.
I would like to get some more info on this before I go to a garage or would be happy to try minor adjustments if I had some guidelines.
Do the catches on the roof move slightly?
There are also adjustable bolts on the roof frame above the front windows - can these be adjusted?
