robinsykes
- Dec 27, 2005
Window goes up to about 1/4 inch from top and motor keeps going. Window will lower all the way down and motor stop. I can manually lift window last 1/4 inch but when I try to lower with motor it just whirrs. When I pull it down manually the 1/4 inch the mechanism engages and the window lowers perfectly.
Is the problem with the motor drive to the lifting mechanism? or is it the metal teeth in the lifting mechanism. i.e. will a new motor fix the problem?
