1995 Mercedes c220 w202 chassis replace wiring harness
diggerbee69
New Registration
1999 Mercedes e300 d
trying to remove wiring harness, in my 95 c220 w202 have it all undone but have two wires running under the intake manifold which i cannot follow, locate or remove. I was going to remove the intake manifold for access, so far i have only removed the fuel rail. At the very back of the intake manifold against the firewall there is a diagram mounted over top of the intake manifold bolts, it is connected by about a 3/8" pipe that runs to the manifold plenum, to remove this and gain access to the manifold bolts I will need the remove the throttle body and linkage first.
Is there an easier way to trace and remove those two hidden wires? Or is what I am doing so far the way to go? So far I have not removed any intake manifold bolts.
