sidevalve
- Dec 7, 2019
- 1995 E220
I have just changed my front wishbones (the ball joint broke off one of them, luckily when I was parking, so I thought I'd do em both!). Anyway, when I was putting them back the cam-shaped bolts only fitted back in one position, so I thought I couldn't have got them wrong - there are two raised edges that they fit in between, and the only way the cams would fit in between the raised parts was in one position. Pic shows the right-hand one in its original position, before I started the job.
But after I had done the right-hand one (I did that first because it was the one that had broken), the steering wheel moved round to the left about 30 degrees (i.e, it is 30 degrees to the left when I am going in a straight line). Doing the left hand wishbone had no further effect on the steering wheel. I assume that the right-hand cam bolt has gone back in a different position, and I hope that this can be sorted by adjustment. However, the adjustment is beyond me, and having looked at a few posts on here it seems to be a rather complex issue. Some people seem to be of the view that it is best to go to a dealer, but I am really anxious to avoid this, partly because I am in France and I would rather eat my own leg than go to one because they are so expensive, and partly because, in my one contact with them, they treated me with considerable disdain because my car was so old (and, I suspect, because I wasn't going to spend €1000 with them...). So I think it is quite likely that they would charge me a fortune and not fix the problem (been there, done that, with other garages here).
So... any suggestions? If I take it to a tyre place will they adjust these cams as well as the track control arms, because it looks as if both need doing. I am anxious to avoid both uneven tyre wear and an off-centre steering wheel!
