Hi, this is my first post so would just like to say a big HELLO to all the members.
I had a 300SL (1993) for a few years but had to sell her due to hard times a few years back.
I today had an opportunity to buy another SL that may need a bit of TLC. She is a 1995 SL 280.
It may be best if I "paint the picture" first as it may help diagnose the faults.
1) The guy I bought her off could'nt get the hood (hardtop) to release.
2) The guy manually released it and it would then work intermittently - including the soft top.
3) The guy had to SORN the vehicle.
4) I went to take a look at her today, and when the battery was re-connected after a few weeks of being off. The hardtop released first time, and then closed fine.
5) I bought her - I got her home and the Hard Top would not release.
6) The guy manually released the hard-top, but the soft top will not come up.
7) When I pull the red-light lever backwards and hold it, the back leather panel moves down slightly then back up when released. When pushed forwards it blinks and nothing happens. The rollbar operates from the rollbar switch.
8) I don't know if this information is relevant but the ABS and ETS are lit up on the dashboard. I have no user manual so cannot check any procedures.
9) I have the battery on charge now overnight incase it is down to this. I also have access to a booster pack.
10) Do I need to check the hydraulic fluid level? If so any help in locating this would be very welcomed.
11) I have tried re-programming the windows as per some earlier posts. The passenger side seems to work normally (small press only goes down till i take my finger off, hard press and the window goes all the way down automatically). When I does this on the Driver side window the window seems to work ok on a small press, but with a hard press it goes down in small increments.
THANKS for reading, all info GREATFULLY RECEIVED.
