1995, W202 - water leakage from somewhere in my car
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
hi guys, over the last two weeks or so i've noticed my yellow RAD light come on meaning that i need to check the water level.
I have checked the water level and indeed the expansion tank was empty so topped it up with coolant, a few days later, same thing happened, odd i thought... but filled it again, took a quick look around the radiator noticed no obvious leakage. Today yet again same problem so pulled up to a car shop and bought some more coolant, when i came out of the shop noticed a very small puddle beneath my engine, so pulled the car back and smelt the liquid, it looked like coolant.
I then looked more closely at the radiator and it seemed dry on the outside, but there was water dropping from the Alternator area, i just couldnt pin point from where...
so, if my rad is ok (and i'm not sure yet) then whats the obvious problem ? my water pump or a hose or ???
advise appreciated
cheers
anyweb
Ellsy Tanners
Mars
The water pumps are very common on your 111 engine anyweb. They leak out off the bottom as it leaks passed the bearing.
Just out your finger under the water pump, and you will feel if it is wet (engine off) water pump is common
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
which one is the water pump before i look, and yes i know which is the alternator... just not sure about the water pump
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
ok i'll have to take a look when its light, do you think its safe to continue driving the car until i get it fixed ? and what is the fix exactly ? replace the water pump ??
Yes change the pump,, my 300TE leaked for some time when I was in Sweden, whilst in Stockholm it fell apart so do not leave it too long
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
ok guys is it a job i can attempt myself or best for my indie ?
anyweb
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
please do, it'll help me to decide how much effort i'd have to put in as time is limited
3 Emails sent, they cover the whole job
Dec
Ireland.
W202
My water pump was replaced last April, by Independ, €200 including labor, not MB part. It started as a slow leak from the pump, the water was blown on to the belt by the fan and the belt drenched the alternator causing the car to almost cut out
I was lucky, as I was only a mile from home. A small leak can turn big very rapidly so don’t drive very far and keep a close eye on the temperature.
Dec
R
recycledjuvenile
mine leaked like a sieve for 3 days on to the belt, after i flushed the system.
I was topping up every day.
Then mysteriously, it stopped. and that wasthe end of the leak.
There's your answer if you want it to last.
Don't go to Stockholm! :mrgreen:
I was living there then:D
The cost was not that high back then in 1992, £125 fitted by MB
www.ckinsurance.co.uk
