1997 C200 Sport. Noise ?
carpcrew
Hi Everyone, Ive Just Been To My Local Garage To Have Diff/ Gearbox Oil Checked , The Reason Is Ive Got A Not Loud But Noticable Humming/ High Pitched Noise Coming I Think From Gearbox Area, Its There In All Gears ( Manual Gearbox ) And Goes When I Accelerate But Comes Back When I Lift Off Or Cruise,even Tried Turning Off Ignition And Coasting But Still There, Clutch Up Or Down, Anyway Oils Are Ok, Im Puzzeled, Any Ideas Would Be Appreciated Thanks Rob:d
This is the pinion bearing in the differential (rear axle) there are firms out there that rebuild them, where in the UK are you
C
carpcrew
Hi Mate Im In Boston Lincs, Sounds Expensive, What If I Fill Diff With Molyslip , Would That Help, Is There A Way Of Checking To Make Sure Its The Pinion Bearing, Thanks For The Quick Reply , Rob
Your fault is too well known to be anything else. there is a firm in Milton Keynes that does this. thats not very far for you. if you do a search here you should find it,its only a few weeks back.
No additive will help
