vobrid_diesel
- Feb 6, 2009
Hi, I have a 220 CDI what has a strange problem:
I had a problem with my mass airflow meter and replaced this, right after replacement my high pressure fuel pump broke down and just have that replaced now the car has a problem starting even when the engine is cold or hot. (no glowplugs I assume).
In order to troubleshoot I used a cleanable fuel filter what has a pretty big cup what should hold fuel after I switch the car off. I found out that somewhere somehow the fuel go back to the tank with a result that once I try to start the car it will take about min before the fuel reach the high pressure pump. Once I have the car started (yes 10 min even when cold or hot) the car drives fine, no loss in power either but as soon as I switch it off and try to turn it back on it takes another 10 min. Anyone any idea? I live on a small Island in the Caribbean and the garages here are without any knowlage about Mercedes.
Thanks!
Thanks!
