1998 C220 Diesel ABS Problem
mercedes13156
West Lothian
CLK 200 Cabrio and a Ford Kuga
Hi there, This is a continuation of a previous thread. My ABS light is on and won't go off. If I start up with my foot on the brake, it goes out like it should. When I release the brake, the ABS light comes on again. If I start up without the brake, the light stays on all the time.
I've just pulled the front hubs off and cleaned up the slots with a wire wheel on a drill and cleaned the lenses of the light soursce. I assume that's what they are.
The problem is still there. Is there a chance that I've fixed the problem, but need the fault codes reset?
There's no overvoltage thing. I've looked everywhere and Television has been pointing me in the right direction, but still nothing!
Thanks in advance!
Did you try the brake light switch
hello willie, have you tested the brake pedal switch and the pressure sensors under your servo? if the light comes on only when you release the pedal it suggest a fault with one of the above.
Would that be the pressure or travel sensor for BAS in the servo
mercedes13156
mercedes13156
West Lothian
Thanks guys! I'll have a look at the brake light switch tomorrow. What should I be looking for? I've had a good at the brake servo and these doesn't appear to be anything hanging off it. Any ideas what I should be looking for there?
Willie
im not sure the 202 had BAS. neither of the ones i had were BAS equipped anyhow
mercedes13156
mercedes13156
West Lothian
I'm pretty sure it doesn't have BAS, whatever that is, so it'll be the brake light switch.
BAS is the brake assist system fitted to later c class cars and bigger e and s class cars (and other models too im sure) of that era
BAS was fitted as standard late 1996,,ESP was not standard till 1999
Ali007
Brussels, Belgium
C220 1997 Diesel
MB C220 Diesel
Dear Friend, i have 1 question, MY Mercedes Benz 1997 Diesel, have same problem with ABS, before some time durring i drive and push the break padel it make car ABS light off and every thing work's good,
but now since 2 months its remain on always, can you explain me how can i chick where is problem even cabel is good.
2nd in morning when i start my car always its start on 1 switch but it missing like it will go off but not and after 4 secounds its normal,
i'll wait for your reply
thanks
Ali
