swtlee
Hi All
My C240 is leaking water from its cooling system. I can drive about 1000 miles before the warning light comes on and I need to top up the system. I took the car to be serviced and investigated. The garage pressure tested it and said all was fine. When the light came on again I called up the garage and asked what they would do to further the investigation. Their answer? We'll pressure test it again! Instead of wasting more money with these people I trekked through all previous related posts on this forum and conclude the following: if I can't spot any water leaking from anywhere in and around the engine then the most likely candidate is that the water pump needs replacing.
I would just like to know if there are any other checks that can be made and any other possibilities for the problem? FYI the car has 45000 miles on it.
