1998 SL60 AMG Window not dropping
tsmat
The drivers door window does not always drop approx 10mm when the door is opened or raise when door is closed. I assume there is a microswitch or something that sticks or poor contact somewhere. I have reset windows and checked fuse contacts. Any ideas or location of any switches etc. would be much appreciated
tsmat
When you say re set you have held the button up for 10 sec with key turned to 2 ign on
T
tsmat
Yes Malcolm - this is a fault which happened very occasionally when it first started about a year ago but has gradually got more often until now, after standing thro the winter, it does not drop at all - I think it is possibly a bad connection because there is sometimes a delay after opening the door before the window drops.( there was when it last worked !!!)
Regards
tsmat
Regards
tsmat
I did not have much luck for the last one of these, but yours is the same as the one that I had, I will see what I can find
T
tsmat
Does anyone know what triggers the window drop - is it door opening mechanism, a microswitch somewhere or ?
Regards
tsmat
