1999 C220 CDi Cabin Heater Fan
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Eric4, Oct 31, 2012.
  1. Eric4
    Eric4 Member
    Apr 13, 2010
    My heater fan stopped running. It then started again but finally it has stopped showing no signs of life! I have the Haynes 3511 which gives clues as to what is wrong. Can anybody advise as to what they know of the problems with this unit and how easy it is to get at and cure! Thanks
  2. television
    television Always remembered RIP
    164,074
    285
    Your Mercedes:
    I can give you the instructions for taking it out,,, you can buy the carbon brushes from Ebay if the commutator is OK
  3. OP
    Eric4
    Eric4 Member
    Apr 13, 2010
    That would be great thanks for your time.
  4. television
    164,074
    285
    Your Mercedes:
    Pop your Email address up this evening and you can edit it out a bit later
  5. OP
    Eric4
    Eric4 Member
    Apr 13, 2010
    a
  6. television
    164,074
    285
    Your Mercedes:
    OK and sent, you can edit out your address now
Share This Page
