1999 E300 D Very noticeable flat spot intermittent
pcman_jh
Haddington
2013 E220 Cabriolet
Anyone shed any light on this -
Two scenarios here -
Cold starts fine in the morning but when I try to accelerate moderately past around 45mph it intermittently hits a very noticeable flat spot, albeit a little lumpy. You can floor the pedal, but it just stays limping (and lumpy) at 45 mph. If I limp along for 30 odd seconds and try not to push the acceleration too hard it then picks up speed and works fine.
Second scenario - After having driven around on a journey (as much as 30 miles) and then I try to accelerate moderately when I'm at speed 60 -80mph it will flatten again (with a little lumpiness). I've got to release the throttle a bit and allow it to get up to speed (or faster) in its own time.
This is not always there which puzzles me. I've just changed the fuel filter so it's not this - as the symptons can describe fuel starvation.
I've read about bubbles in the fuel lines, air mass meters, turbo valves etc, but where do I start?
This is the 6 cylinder bosch inline engine, not the CDI, so I wouldn't have thought there will be an electronic skull duggery going on, and it'll be something mechanical(ish).
Any help would be appreciated.
Parrot of Doom
Manchester
Whos going to suggest the obvious suspect then?
EGR valve stuck, I am sure that it has one.
malcolm
P
pcman_jh
Haddington
2013 E220 Cabriolet
Can anyone explain even although there is an improvememt
Can anyone explain why changing the fuel filter makes a noticeable differnce, althought there's still the flat spot when half warmed up and trying to moderately accelerate past around 45mph.
I suppose I should qualify the issue arises (1 out of 3 occasions) when applying the moderate acceleration and on a slight incline.
I'll check out hte MAF tomorrow.
popsicals
Cheshire
popsicals
My E300TD has a vacuum type valve located under the inlet manifold which has a flexible pipe leading to a box next to the screen washer bottle on the inner wing.
If this is split or has been accidently disconnected then you will have the problem you have discribed.
