glendind@hotmail.com
- Nov 23, 2008
Hi all, on sat ckeck coolant level warning was dispayed so i drove a mile home onlyto notice a slight leak under the car i topped up water to correct level,went to work the next day only to find a larger puddle .i then noticed the top hose from rad was completely flat so i undid the filler cap and the hose returned to normal .if i run the car with this slightly lose i do not have any water loss.so could the problem be the cap not allowing pressure decay and pulling a vaccumm when the engine cools down. the leak seems to be just above the water pump by the turbo.when the cap is tight.does this mean that when system is under pressure that water will find the weakest place to leak from. help much apreciated, Steve
