1999 E320 won't start
rallen1162
I replaced the fuel pump, fuel filter and the Crank position sensor and still wont start. Last time I had this same problem the crank sensor replacment did the trick. Now it only cranks and cranks. Any suggestions anyone?? thank you:(
Hello and welcome..is there any way that you can measure the CPS it should be 1k ohm near enough
R
rallen1162
OK work with me please. I do a lot of DYI but dont know what the CPS is.
R
rallen1162
already replaced the crank sensor
could I have purchased a bad one?? how do you check??
