Jon Bernard
- Mar 9, 2007
Hello all,
is it the ecu. a relay or a fuse I don’t know where to start. My 1999 W202 C230K developed a misfire, 1 plug was fouled I replaced spark plugs. (I didn’t on this occasion remove the battery earth lead & think I also trapped 1 of the black wires from the front coil between the back coil and its seating on the rocker box :Oops: ) after reconnecting everything I tried to start the engine to no avail, when the engine stops turning over I can hear a fairly high pitched electrical processor type sound appearing to come from underneath were the injectors are, I can smell fuel at the exhaust, any ideas of what my problems maybe?
P.S. the connectors with two coming out of on the coils are in fairly poor condition, the plastic has bits broken off, but the two pins still seem to be connected into the coil.
Thank you
Jon
Thank you
Jon
