2.3-16 valve clearance
Status
Not open for further replies.
chris-edinburgh
Ive just measured my valve clearance,, these are the readings...
Exhaust value Inlet value
8 0.18 8 0.08
7 0.18 7 0.1
6 0.23 6 0.1
5 0.12 5 0.1
4 0.18 4 0.1
3 0.18 3 0.1
2 0.25 2 0.06
1 0.18 1 0.08
Is it common for the clearance to be less then specified? id have assumed that clearance increase with engine age (167000 miles)
Exhaust should be 0.25 - 0.35
Inlet should be 0.10 - 0.20
C
chris-edinburgh
  • #2
table didnt come out very well.. valve number to the left....
Exhaust value
8 0.18
7 0.18
6 0.23
5 0.12
4 0.18
3 0.18
2 0.25
1 0.18
Inlet value
8 0.08
7 0.1
6 0.1
5 0.1
4 0.1
3 0.1
2 0.06
1 0.08
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hi Chris,
All of the Mercs I have owned through the years have shown that the clearance gets less and less as the valve beds in to the head more and more. I remember the clearance got so tight on my 240D that it kept the valve ever so slightly open resulting no compression.
Saying that I never had a 16 valver.
Regards
Mike
C
chris-edinburgh
ah, i see,
did you find the different sized shims easy to get a hold of?
Mikesmerc
Co.Cork IRL
Chris
my brother used to work in an engine overhaul shop so there was no problem at the time. Saying that all the old Mercs I owned didnt have shim adjustment-just old fashoned spanner adjustment. Only thing I used to get done is to renew valve seats, reface or replace valves. Im sure if you visted your local engine overhaul shop you should have no problem.
Regards
Mike
Status
