Hi i have managed to drill out the head on the seized distributor cap screw and lift off the cap (which was broken ). i am now applying penetrating oil to the exposed thread in the hope that after a while i can get a pair of grips on it and turn the screw out. Failing that i will have to remove the distributor and do as Orlando 300 suggested and hold it in a vice and turn it out.
one question: (as i know very little about these things and am going on a 190e haynes manual and a limited box of tools!)
do i have to turn the crankshaft to bring number 1 piston to TDC before i can remove the distributor without losing its alignment? or can i just remove the distributor after marking position of the distributor clamp bolt and rotor arm?
thanks for any input you can offer
rgds
Bob
rgds
Bob
