ukhozi
- Feb 13, 2009
- Location
- Estepona, Spain
- Website
- ukhozi.page.tl
- 1987 2.3-16v, 2001 A170 (W168) Elegance TDi Auto, Eagle SS /VW kit, 1999 Suzuki AN400
- Thread Starter
- Thread starter
- #21
There is fuel returning to the tank and when the pumps run first thing in the morning as opposed to re-run after the pressure has built up, they run fast and then as pressure builds quickly and they run slower just before shutting off, this indicates a build up of pressure in the system also.
Just in case the FPR is too open and not providing the 5.8 bar back pressure required, I am going to restrict the return pipe to artificially create resistant and build a guaranteed pressure in the distributor. We’ll see what happens.
Bit limited as to how much I can do in a day as it’s in an underground garage under the house and even with a large fan going all the time fumes build up to a point I have to pack it in and wait for the area and my head to clear.
I have to get it started before I can do a "hot" test. Return flow to the tank, engine running or when ignition on and sufficient pressure already in the distributor?
I know I should do a pressure test and I spent most of yeasterday trying to rent, borrow a set of gauges with no luck and I cannot afford to buy any.
