mikeA
Hi, I,ve got engine problems with a failed oil pump and I would like to know it it's driven direct off the crank or by a chain off the crank.
This is cause my pump failed and when i noticed I pulled off the road with the clutch dipped and the engine stalled, it will not turn over now. I don't think it's seized as there was no drop in power / smoke noises etc, apart from a noise as the engine stopped. I did think it may have been the cam chain tensioner slackening as the oil pressure dropped but the pistons are not near the valves. I'm now wondering if the oil pump chain has broke and got caught under the cam chain ?
Mike
Mike
