F
fester
Guys one of our Jeep drivers over here has a problem with one of his injectors. Apparently it's had 3 goes at seating after addressing some black death issues and he feels now the injector does not pull down through the rocker cover sufficiently to seal on the washer properly. He also has the issue of the injector bolt hole thread stripped but that is a minor hassle.
I've not done my injectors yet so not sure what he can do. Is it possible to use 2 of the copper washers to take up the slack or is there a thick washer available. Or does anyone have another solution. He says there is a lip in the cover that the injector body hits rather than pulling firmly on to the washer. AT least it seems that is the case. To confirm he has recut the seat each time but keeps getting blow by around the injector. Number 3 injector if it makes any difference.
