alchemist83
- Nov 3, 2019
- Location
- Kent
- CL203 C220 CDI 2006 (EVOLUTION S - AMG STYLING)
So recently replaced MAF complete with housing, air temp sensor and MAP sensor pre-fitted. When I ordered the MAF I couldn't tell if it came with a MAP sensor, so ordered 1 also. Now its a spare. I had a code at the time stating that charge boost pressure has an issue, which I previously thought resolved because when changing the MAF I found the turbo air pipe to it was very loose turbo side. Tightened the fitting and deleted the code. Has been fine since it seemed, but on recent checking after car being odd, the code is back.
My question is; are the Intake Air and Manifold MAP sensors the same? They look identical (the one in the MAF housing and the one near the manifold / egr area). I've had a good internet search and cannot really tell. I used the part numbers but still can come up the same when they ref OEM part number. But for instance Eurocarparts lists them differently / separately with different prices. If I can replace the Manifold one with the spare - supposedly Air Intake one that'd help.
Cheers
Cheers
