2 quick questions please clk 320
ozbod1
hi guys, i bought a clk 320 around a month ago and im really happy with it just got 2 questions..1 it has a auto/tip box with a w/s setting, should i be in w or s for normal driving??? i always thought that w = winter s = sport but according to my handbook s= standard so which will be the best for mpg? 2 the only thing that dosent work is the multi-function steering wheel, if i pull the lever nothing happens, i did notice on the service history that it had a new indicator stalk due to a fault so would it be possible that they didnt connect the multi-function steering lever up correctly when fitting the indicator stalk?? also is this a diy job to fix??? many thanks spencer
jibcl500
Cambridgeshire
CL500,ML55,SLK280
W winter S standard, try the same route to work and see what difference it makes, it should give better mpg on W.
Sounds about right for the s/wheel, best get it to an indie for them to look at, you have an airbag!!! so best not to mess about unless you know what to do.
jib
David Nock
South Yorks
CLK/2009/320CDI
I use S all the time on CLK 270 CDI, because it goes great on that setting. If I ever change to W, I'm disappointed within a couple of roundabouts so I switch back to S for another year!
brandwooddixon
Wolverhampton
S63 Coupe 2014
W will mean that you'll pull away in 2nd and it'll change up sooner.
S is better for fast driving.
PaulMdx
I believe the W / S is related to how the car changes gear. In Winter mode the car will generally be in a higher gear to reduce the likelihood of losing traction with the drive wheels. In standard mode you'll get a bit more power as the car is more likely to stay in a lower gear giving more torque.
FELLOW
S/w
Had the same thoughts when I got my CLK 320.
I would suggest running in S mode unless their is snow on the road.
The Merc CLK isn't bad in the snow but depends on how much tread/chain/winter tyre is on those big size wheels...traction/ESP is v.good.
Remember the gear box adapts to your style of driving to a degree.
O
ozbod1
ok thanks guys ive tried w today but it isnt for me so il stick to s and soak up the extra mpg..lol with regards to my non working multi- function steering wheel is it possible to get at from undeneath without taking the wheel off etc??? many thanks spencer
GMK
Glasgow
Sadly, I bought a 200K so for me it's S-slow and W-woeful........
