2000 CL500 Battery keeps going flat
babyface
I have a 2000 cl500, the battery keeps going flat, some times it is fine for 3 weeks, then it will go flat every day, I have replaced the battery twice using the correct type in bosh silver make. I have checked all systems with a modis and nothing comes up with any faults.:cool:
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
their has to be a system drainig the system a trickle charge would do it
it could be anything from an alarm , radio , parking sensors ,
hope fully some one will be along soon to help more but i would disconect any items that are not a factory fit and go from their
The drivers seat module is a reason, and again it could be a SAM you either insert an ammeter in the circuit and with draw the fuses one by one or plug it into STAR
Ellsy Tanners
Mars
Check for any water under the drivers side rear seat, thats where the sam unit is and can cause a battery drain.
other than that it is as malcolm says, a drain check whilst removing fuses.
A draw of 0.04 amps or 40 milli amps is ok, anything like 0.1amps is too much and will flaten battery after a period of time.
Yes spot on,, the last CL that saw. MB got it dwon to 42m/a and gve up. An S Class they got down to 48m/a.
The art is connecting up the ammeter so that the path of the leak is lost, do this by connecting another battery up first in parallel
B
babyface
Thank you
Thank you all for that info. I will give it a go and letyou know how I get on.:cool:
David Nock
South Yorks
CLK/2009/320CDI
I think you meant to say 'path of the leak is not lost' Malcolm? I did a bit of head scratching until it clicked what you're saying - the leak shuts off and often won't replicate IF you completely disconnect the battery supply.
