mercedes ben
New Registration
- Feb 13, 2009
Vin(208.448)
I've looked through the forums and at the Russian parts diagrams, I've pretty much had the assembly apart - but I still can't fathom how its supposed to be. - Please share any light...
The manual handle/release for the roof, at the top and in the center has become very stiff. There is a circular black holding piece that the handle stem disappears into and this moves up and down by a centimeter or so - I dont remember it moving like this before. And now won't always move the two locking arms at either side. (not without a degree of wiggling, jiggling & pulling)
The actual mechanism works fine (the rods, and locking arms, etc.) I have just unscrewed the four screws that hold the plastic cover which runs right along the front, and the four "poppers" so this cover was loose and I could see into the problem area without removing the handle.
(There appeared to be some kind of locking pin rather than a screw or bolt for actually removing the handle itself, which I might end up needing to get off if anyone can tell me how that comes off, and goes back on!)
I fiddled about with the spring inside the mechanism that had come unattached. And got the top of the spring back into one of the holes, and the other end of the spring back in the holding slot on the piece that swivels with the handle.
I thought this would resolve it, put it back together - but no joy... I don't know whether the spring should latch/catch with any other parts of the mechanism to make it work?
The roof will go up and down still, but the unlocking/locking handle I need to push up and pull down on the handle and it is in no way as smooth as it was.
Has anyone else suffered a similar problem, can anyone tell me how to fix it, has anyone seen a schematic diagram for the parts I'm talking about, etc...
I want it working properly again
Thanks in advance (and for taking the time to read through that!)
Ben
Ben
