just bought 2000 model clk 230komp, the glove box won't open with the key, I think the lock is broken any other way to open the glove box any help would be very much appreciated, Cheers Shaz.
Not easy, the barrel would appear to be OK, one can also fit new ones but it must be open to do it,,will the button not depress with the key turned, or is it not pushing in.
I got bit excited of the possibility of glove box being full of money and pulled a little harder and lever came off and behind it its an empty hole that can't be right?, the key turns the black plastic lock at the back of the lever but I don't think it's hooking on to anything just keeps turning.....
