2000 w reg E320 CDI can't start! No glow plug light
steve berry
Hello everyone,
My E320 W210 does not start. Once the key is in the ignition, the dash lights will function as normal until you get to stage 2 of turning the key, there is no glow plug light at all, and when I turn the key to start the engine, nothing....
no malfunctions or any warning lights, just silence as I try to start the car?
Is the starter motor possibly stuck or is the ignition barrel not working properly.
The car has not been used very much in the past year or so.
Hi Steve,,,there is a good chance the the cooling fan in the fuse relay box has gone short circuit,, take off the fan and cut the wires off, as you do not need it and replace the K40f4f5 fuse.
That should get you on your way :D:D
