2001 Mercedes clk230 compressor cabriolet roof problem
Discussion in 'General Mercedes-Benz Related Discussion' started by Nickvanes, Feb 10, 2019.
  1. Nickvanes
    Nickvanes New Member
    7
    Feb 7, 2019
    Your Mercedes:
    Clk320 2001
    im asking for a friend of mine who is a little shy about posting himself.
    He has problems now since he went over a speed ramp a little too fast which caused the rear headrests, roll bars, to shoot up, due to this the roof and windows will not function and it seems to be causing the battery to drain very rapidly although that might be unrelated.
    Short of going to a dealer to sort out the headrests and hopefully everything else is there a self cure solution anyone can suggest.
    Thanking all you experts in advance for any advice you can give.
  2. Wighty
    Wighty Senior Member
    5,195
    2,434
    Aug 4, 2016
    Your Mercedes:
    Well he has triggered safety systems , what does the owners manual say about resetting ? If it doesn't say anything he would be better going to an MB Indy , which will be much cheaper
  3. brianbrian
    brianbrian Senior Member
    2,552
    96
    Sep 27, 2008
    cockney in the West Country
    Your Mercedes:
    w124 250D, SL129-deisel
    You need to look under the car, maybe the safety switch that works with the safety bar has broken . Only a guess
  4. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    10,697
    1,367
    Mar 25, 2010
    Dartford
    Your Mercedes:
    On the W208 CLK, you need to press and hold the "headset down" adjustment button on the dash. After a few seconds, it should make a clunk from the back and start retratcting the headrests/rollbar.
  5. OP
    Nickvanes
    7
    Feb 7, 2019
    Your Mercedes:
    Clk320 2001
    Brian could you tell us where the switch is please.
  6. OP
    Nickvanes
    7
    Feb 7, 2019
    Your Mercedes:
    Clk320 2001
    We have tried that and no luck at all, we have tried holding it in position up and down for 20 seconds and not a movement or noise.
  7. alexanderfoti
    10,697
    1,367
    Mar 25, 2010
    Dartford
    Your Mercedes:
    In that case, the adustment mechanism has an issue. Check the fuses etc for normal function.
  8. Wighty
    5,195
    2,434
    Aug 4, 2016
    Your Mercedes:
    Was there anything in the cars manual ?
  9. brianbrian
    2,552
    96
    Sep 27, 2008
    Your Mercedes:
    The switch is under rear off car, when one off the wheels axles lifts of the ground it makes contact and sets the bar of.
Share This Page
