airbag
Hello, I have a 2001 C320 Estate.
Its a good car with only 46,000 on the clock, but a major headache I have is the suspension.
It can be good under some circumstances, mostly forward and back (potholes etc) , but constantly gives the same feeling as if you were wobbling the steering wheel right, then left, then right again etc when going over road bumps. Its like a sideways wobble as if its not tight enough to stop wobbling.
As mentioned, the estate is a 2001, but only has 46,000 on the clock and is an Avantgarde model. I would have expected better suspension than it has.
Would it be worth fitting after market shocks or springs to this? Has anyone found a good kit that works well with the C Class models?
Any ideas would be appreciated thanks to help address this issue.
