dave123
New Registration
- Aug 12, 2011
- slk 230/2001/230 kompressor
I have had my 2001 slk 230 kompressor in storage over the winter and when i have come to use it I have put in a fully charged battery and get the 'start error' message displayed on the dash when i try to start it.
The key has had the batteries replaced and it is still able to operate the central locking, but when the ignition gets to the point where it would usually activate the starter, nothing happens. The car won't even turn over and just displays 'start error' on the dash.
I have tried the following things so far, all of which have done nothing:
Changed the starter motor
Checked the k40 relay board which looked ok
Checked all the electrical connections under the dash and made sure they were all seated correctly
Changed the batteries in the key fob
Checked all the fuses
After browsing this forum for a while, am I right in thinking that it may be a problem with the DAS system? ie the ECU is no longer recognising the code from the key?
I'm really out of ideas now as to what the problem could be, so any suggestions or potential fixes would be greatly appreciated.
Thanks in advance
Thanks in advance
