2001 SLK BAS warning light diagnosis
stonty
S320/2001/3.2
Hi fellas,
My sister has a 2001 3.2 SLK which has had an intermittent BAS light warning for the last month or so, today she had the car hooked up at her local Mercedes dealer who diagnosed the that problem was either the brake light switch or the lateral acceleration sensor, cost for them to change both is £379.
I figure that I'll change the brake light-switch for her & see how it goes, should the problem turn out to be the lateral acceleration sensor have you guys got any pointers as to where its located, is it a relatively easy fix etc?
Many thanks
Chris
Yes spend £10 on the switch,,if if does not cure it I can give you a work sheet for the rest :D:D:D
stonty
S320/2001/3.2
Thank you Malcolm that's great, hopefully it'll just be the brake-switch thats the problem :D
5pares
Suffolk
E320cdi
The lateral accel sensor is under the centre console.If the bas light comes on when the brake is pressed its prob the brake light switch.
stonty
S320/2001/3.2
Thanks fellas.
I pick up the brake light switch on Thursday, in my minds eye the swap over is to easy for words, but just in case is there any niggly little surprises in store for me? lol :eek: :D
stonty
S320/2001/3.2
Honestly guys?
You mean I wont need my "Bicycle Repairman" tool-kit? lol
stonty
S320/2001/3.2
Hi guys,
I switched over the brake-light switch this morning & the BAS light is still glowing, I even disconnected the battery for 10 mins to see if it cleared but to no avail :(
Now turning my attention to the lateral acceleration sensor, is it much of job? Any pointers would be much appreciated, its gotta be easier than the undignified "head down-bottom up" contortionist procedure involved with the brake switch :)
Thanks again
Chris
As 5pares above, but just in case
K
karlos2000
newbie with just this problem, SLK 230
hiya guys, new member here, with a 1998 SLK230, owned it for 7 years, just struck her up for the summer and my ABS / ESR light is on permanently, also, the roof won't operate, I guess the roof fails as a safety option due to the ESP shutting down??.
So, after reading the detailed posts here do I change the brake light switch first and then the latteral acceleration sensor second?
by the way, the brake lights still work, does that mean the brake switch is not duff?
ta in advance
Karlos, Lincs
turn the steering full left to right and restart, try that first!
K
karlos2000
with the engine running? forgive my abject stupidity, but, I turn her on, full lock left, full lock right, switch off, restart> yeah?
just tried that, lights still on ......... I see that the engine has to be running as you can't really turn the wheel without power steering! duh :mrgreen:
ta for the welcome
As for the roof, as you push the button push the roof up with your hand, the roof seals glue themselves together!!
K
karlos2000
nah mate, fully familiar with that one (roof), this has only started since the ASR and ABS lights came on .... the roof just won't operate (no whirring etc), light just flashes as if the boot flap microswitch isn't engaged, but too coincidental to be unconnected I figure. I've had the old SLK intermittent roof failures before & I just live with it, happens 2 / 3 times a year, but always clears up, this is deffo different.
Have you tried to lube all the rubbers around the roof, that the dealer method, and do work 9 times out of ten!!
K
karlos2000
yeah, I do that at least twice a year, this is 101% a new one on me, as I say, normally if the roof is going to play me up, I get the boot come up, all the noises and right signs and just as the roof is about to open, it doesn't; this time it's just the flashing button, but this all since the 2 lights came on. Seems I need to start with a new brake light switch, then the B24/2 sensor, then if all else fails it's down to the specialists for a diog .....
