enes
Following my previous issue with seals and non-start due to injectors. I recon'ed 3 of them and no black smoke appears under load.
However, there is a knocking noise at low engine speed/idling when say manovering around a car park. This is more prevalent when starting from cold, it starts fine and then after about 4/5 seconds, the car doesnt idle properly (gets louder and rpm sounds like it falls slightly) and you can hear a knocking noise coming from the engine gets slightly louder as you rev the engine. It tends to fade away as the engine gets to 80c or when driven under load for a few minutes.
Any ideas?
Does it sounds like an injector issue?
180k on the clock
Any ideas?
180k on the clock
