enes
Hi All,
I have a E270 CDI with new copper injector washers fitted. there is compression as seals seem air tight. 3 injectors had tiny balls missing which I bought (ceramic not sure if it makes a difference between steel but I was told this injector takes the ceramic ones) and they fit well so injectors should be ok. the other 2 had not been opened up at all. it has no sign of firing up and the error on the scanner states low fuel pressure. this car was working perfectly before but it has not been cranked for 3 months and had been sitting for 6 months prior (ran at idle at 1-2 week intervals during this period).
The car cranks but no sign of firing up, it burns up the easy start but does not start up.
I have topped up diesel above 1/4 tank. It does not start with easy start.
Any suggestions?
Fuel filter was changed 2 years ago (4000 miles ago).
Any suggestions?
