Axcontrols
- Nov 1, 2006
- 53 ML 270CDI, 2017 GLA200d
Lights on the dashboard. Fault code say rear right speed sensor. C1130
Vehicle stationary. So not driving/moving. Just the ignition on. Clear the fault and then immediately read the fault and it's still there.
Replaced sensor with a known good one and the fault doesn't go away.
Checked the wire going up through the floor under the back seat and it looks fine. No chafing.
Another question on the forum mentioned something similar which he thought was related to moving his drivers seat (RHD) forwards/backwards. Does the wiring for the RearRight speed sensor go anywhere near the seat rails or seat adjustment switches?
Anyway where else I can look?
Oh. Not sure if this is relevant. Car drives normal. No limp mode etc. Just the dash lights on all the time so I'm assuming there's no ABS or traction control etc.
Thanks guys
Thanks guys
