2003 E270cdi Vibration on steering and pedals
AndreasM
Chichester
E270cdi 2003 Avantgarde
Hi all
First time on so dunno even if this is gonna get through.
I recently bought a E270cdi 2003 model, and since buying it i am feeling a vibration mainly throught the brake pedal. At first i thought it may be the ABS as whenever i depressed the brake i saw the ABS vibrating violently, or should i say more than it should.
I then came across a Mercedes Mechanic at work who told me he was 100% sure it was the SBC pump attached to the ABS. He also told me that although there was not a recall, MB would change this pump for free as it had a lifetime guarantee. So with this info i took it along to MB booked it in and they put it on the diagnostics to find no fault.
Still the problem persists.
I then found this site and i start reading about glycol mixes etc.
Now i am really confused.
Can any kind person offer any advise? PLeeeease
Hello and welcome, yes your car has SBC this is a system with a pump to operate the bakes. If you can feel a slight vibration when pushing the pedal, then there is a little mod that can be done where a hose is fitted to stop the vibration from coming into the car.
This must not be confused with when braking and you feel a vibration from the from a disc that may be out of true.
It would be more normal to feel the vibration with warped disc, rather than through the pedal
Just start the car in P and apply the brakes and see if you can feel anything
A
AndreasM
Chichester
Thanks for the prompt response
I cannot feel the vibration when braking, on the contrary it will stop on braking.
When i do what you say the vibration is there but only on releasing the brake. If i however pump it slightly the whole ABS pump shudders/vibrates and it is then intermitten.
I have also just changed the front discs and pads
Frontstep
T210 320cdi
Is your caliper/s on tight and true and did this vibration? start or change in any way after new Discs/Pads
Then have the update,, it is on a MB paper
AF42.46-P-1101A
They used to do this free, but I do not know if they will these days
A
AndreasM
Chichester
Thanks guys
Ok thats helpfull info
will see how we go with that.
This is an excellent site by the way well done all involved
