Holmey
- Jan 3, 2022
- 2003 Mercedes Benz E320 CDi 4 Door
I’ve started feeling what can perhaps best be described as a shimmer through the drivetrain of my 2003, (now), 135,000 mile E320 CDi at various speed when accelerating medium/hard, with this shimmering only lasting for a second or 2 before everything smooths out again. From experience of other cars, I suspect it’s the prop shaft center bearing or it’s support that’s on its way out, and while it’s not too bad, (only slightly noticeable), I want to sort it out before it gets any worse, with apart from this and an occasional phantom orange engine warning light, (more on this later), the car still running like a dream after me doing just under 5,000 miles in her over the past 2 months
I’ve not had chance to get it on a lift and have a look at it yet, but from what I’ve found online the center bearing unit is mounted in a sort of rubber doughnut, and these are likely to start breaking down on this particular model, and I think this is the most likely culprit that’s causing the driveline shimmy under acceleration – Does it sound like I’m on the right track here, or can anybody suggest anything else that could be causing it? With the gearbox being fine, (smoother and more responsive than I expected, with evidence that it’s been serviced too), and it certainly not feeling in any way diff or rear axle related.
If it is the prop shaft center bearing support doughnut, has anybody here ever changed theirs, and if they did, what sort of job was it, as I’ve not been able to find any video guides online and considering doing it myself, with me having the use of a fully equipped workshop and lift and looking for possible problems.
The main thing that come to my mind is if on my model, can I just replace the rubber mounting, or is it all in one piece, it bonded to the prop shaft unit that would mean I had to replace the whole prop shaft?
As to the pesky intermittent orange engine warning lite, the cheeky blighter must have come on at least 5 times now, if not more, and then, it seeming like as soon as I’ve decided to take it to my mate’s garage to put it on his diagnostics, (normally after it being on for a couple of days), it decides to go out and shows no fault codes the couple of times I have run it through diagnostics, (a top of the range Snap On unit that’s just been updated, not a cheap £75 unit from online), with this driving me mad as it’s the only niggle with the car other than the prop shaft
All advice appreciated,
Many thanks,
Holmey
Many thanks,
Holmey
