Vehicle 2003 E320cdi Avantgarde estate for sale. Just £300.
Discussion in 'Mercedes Car Classifieds' started by XL5man, Jul 24, 2020.
  1. davemercedes
    davemercedes Senior Member
    3,552
    1,328
    Jun 15, 2012
    Worcs
    Your Mercedes:
    2007 Merc 220 CDi Est Auto Av
    Well done - I was kind of hoping it would end up at your shop, Alex and if it becomes a courtesy car that’ll really give it a new life!
  2. alexanderfoti
    alexanderfoti MBO Forum Supporter Authorised Forum Supporter
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    It certainly wouldnt have made the journey home at least, at least, not without a spectacular diesel runaway. The amount of oil in the exhaust is very impressive
  3. LostKiwi
    LostKiwi Senior Member
    24,673
    13,806
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    A new turbo us a fairly easy and cheap fix though!
    Oil in the exhaust wouldn't be a problem - oil in the inlet in the other hand....
  4. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    There is quite a lot of oil in both........
  5. John Laidlaw
    John Laidlaw Senior Member
    24,095
    7,611
    Nov 15, 2013
    Wirral
    Your Mercedes:
    UnMercs BMW i8 Volvo XC90
    Haven’t seen a good diesel runaway for a while, spoilsports!:rolleyes::rolleyes::p
  6. bembo449
    bembo449 Senior Member
    5,026
    1,978
    Jan 2, 2012
    gainsborough , lincolnshire
    Your Mercedes:
    Mercedes Cl500, land rover discovery 3 , insignia vxr , shitron dispatch
    Had an Peugeot van do this one day , had to run it into a hedge to stall it :p:D:p:D
  7. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    Lots of progress today. Cause of the smoking was failed turbo. Old one had an inch of play on the shaft! Turbo replaced and exhaust cleaned out, smoking is much better.
    Only issues remain now are:
    NSR wheel speed not registereding, either sensor or ring
    Water pump has sprung a rather large leak, so that needs to be replaced.
    Otherwise, seems quite good!
  8. LostKiwi
    24,673
    13,806
    Aug 25, 2006
    Your Mercedes:
    Excellent! Swap out the bonnet and it'll look a million times better too!
  9. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    It definitely does need a bonnet.
    The injector bolts have been bored out on 3 cylinders to m8's. Not ideal but they aren't leaking so I'm. Not touching them
  10. LostKiwi
    24,673
    13,806
    Aug 25, 2006
    Your Mercedes:
    Yes Martin mentioned that to me when I saw it.
  11. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    It does drive very nicely though. Will report further shortly.
  12. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    A further update:
    Injector number 6 leaking, pulled it out to reseal, found a sawed off bolt and the other half left in the head.
    All 6 injectors pulled, cleaned, rocker cover off, drilled and removed old bolts.
    Going back together tomorrow :oops::oops::shock::rolleyes:
  13. malcolm210
    malcolm210 Senior Member
    4,159
    1,053
    Aug 21, 2005
    Good to see you are giving the 211 another chapter Alex.
    I couldn’t find anyone to repair the rot on my S210 rear wheel wells so took it on myself using airframe techniques as opposed to welding to do the repair with success, the car is still on the road in new ownership 3 years later, in all other respects the car was in very good repair and it would have been a shame to scrap it
  14. Naraic
    Naraic Moderator
    10,290
    907
    Mar 4, 2010
    Your Mercedes:
    2005 CL500.
    Rivets? I did that on parts of my 210. Happy memories.
  15. malcolm210
    4,159
    1,053
    Aug 21, 2005
    Yes happy days, not economic to pay someone to do the job (none willing in fact) really enjoyed the challenge and very pleased with the outcome
  16. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    Car is back together now. Total parts bill:
    Water pump
    1 x injector, clamp and bolt
    front SBC battery
    1 x Turbo charger
    9 hours labour to fix the stripped injector bolts, do the turbo, etc etc
    Pending faults - rear abs sensor intermittent (suspect rusty ring)
    AC re-gassed (not that it needed it!)
    Now driving!!
  17. bembo449
    5,026
    1,978
    Jan 2, 2012
    Your Mercedes:
  18. alexanderfoti
    12,492
    2,751
    Mar 25, 2010
    Your Mercedes:
    Yes, still smokes, but not as bad as before. It would seem the injector seats have been cut 5mm+ so getting the injector height correct is going to be impossible.
  19. bembo449
    5,026
    1,978
    Jan 2, 2012
    Your Mercedes:
    Could that just mean it needs a decent run out tho alex ?
  20. LostKiwi
    24,673
    13,806
    Aug 25, 2006
    Your Mercedes:
    If the exhaust is full of oil it may take a few miles to burn it all out.
Share This Page
