mlc
- Sep 4, 2003
- Age
- 67
- Location
- South Manchester
- 2001 S320, 2003 SLK230, 1972 350SL
We have a 2003 SLK 230.
The SRS / BAS light comes on when you apply the footbrake to change from Park to Drive. The cruise control is not working and the brake lights are not working. If I start the engine in N then select Drive without touching the footbrake the light stays off and cruise works until you need to use the footbrake.
I think that the brake light switch has failed, does this make sense? If I am correct does anybody know if swapping the switch is a DIY job or do I need to get the local indy to look at the car?
